2009 Vue 3.6lXR Exhaust Muffler Replacement
Old Jul 26, 2025 | 12:38 PM
09Vue's Avatar
Default 2009 Vue 3.6lXR Exhaust Muffler Replacement
I have a 2009 Saturn Vue 3.6l XR. The factory stainless muffler has a hole in it, and is terribly loud.
Unfortunately, GM has discontinued the exhaust system parts for this model, nor are there any aftermarket mufflers available for the 3.6l v6.
The only aftermarket mufflers available are for the 2.4l engine models, and are not a fit.
Was wondering what other 3.6l XR owners have done.
Did you find a shop that would patch/repair the OEM muffler and if so.What was the cost?
Or did you use an aftermarket muffler of some sort?..If so.please kindly provide model# of muffler used.
Old Jul 26, 2025 | 02:37 PM
Stove's Avatar
I put on a used one few months ago. $30 at junkyard. Easy. It does not have a rust hole.
bought many parts at yard. 2-3 muffs. I put a 3.5 muff on my 3.0 vue. The pipe is 2.25” and inlet is 2.5”? Approx. I got an adapter at oriellys. Cut pipe in flat section and use band clamp. Easy.
Old Jul 26, 2025 | 02:58 PM
09Vue's Avatar
Many thanks for the reply.
Thats exactly what I've been planning to do. However, I cannot find a good used muffler replacement anywhere.
Old Jul 27, 2025 | 10:00 AM
Stove's Avatar
Does it have dual outlets? The vue morphed into the captiva. I wonder how similar the mufflers are?
Old Jul 27, 2025 | 11:18 AM
09Vue's Avatar
Correct. It has dual outlets, but i was told the second outlet is mostly for looks...
I too have been comparing the 3.0l captiva sport exhaust system. They are similar, but not at all exact...
The captiva's muffler inlet is situated in the center, whereas the Vue's muffler inlet is on the side, but they both join the exhaust system aprox in the same area.
It comes as no surprise that there is no aftermarket mufflers available for the 2012 3.0l Chevy Captiva Sport.
3.6l vue exhaust system
Old Jul 27, 2025 | 05:55 PM
You might need to use a universal muffler like this. 2.25” in, twin 2” out, one on each end.
Old Jul 29, 2025 | 08:13 AM
Stove's Avatar
I work on equinoxes with 3.4. I refuse to touch 3.6 stuff. I was unaware that it had dual pipes from motor. I wonder if a 2010 equinox with 3.6 has same setup? But we are talking about muffler end, not motor end.
Altaskier53058
Nov 10, 2020 12:42 AM
cpufreak101
Sights N Sounds
Oct 25, 2019 08:45 PM
XGMaN0928X
Headers, Intake, & Exhaust
Jan 9, 2016 09:50 PM
08astraxr
Saturn Astra
Dec 18, 2011 10:21 PM
beckmaster
May 9, 2007 10:19 PM
