2006 Vue 3.5L ISO Torque Specs
Hello everyone,
Seems my old account is MIA so I registered again. We have two Saturns, a 2006 Saturn Vue 3.5L and a 2000 Saturn LS 2.2L . We are in Georgia.
I'm not sure where to post and ask questions about torque specs. I'm getting different info on sites I visit.
On the 3.5L I was looking for the torque specs for the motor mount for the front of the engine (passenger side under filter container) to block bolts and the bolt that goes through the rubber mount damper. Seems they're suppose to be 40lbs each but I'm not positive. Anyone ?
I believe the information you seek is near the bottom of the first page and the second page at
2006 vue 3.5 L Motor Mount Torque Specs
Not going to guess which bolts... It's all there for the taking.
Great site for the DIY er. Poke around..🙃😜
Derf,
Hope the AWD & FWD are the same torque specs. The way it's put on the page at the link is just a bit confusing. I installed them at 40 ft.lbs. each.
If they were suppose to be 37ft.lbs. I hope I didn't hurt them
Thank you again.
Thank you again.
I gave you the all-wheel drive. I will double check and make sure they are the same so that you can sleep at night for the rest of your life
Actually I don't know what spec you were looking at, so here is the link to the same information for the front wheel drive.
2006 Vue FWD Torque Specs
