turning over, but won’t start
Old Apr 4, 2007 | 04:20 PM
WiShJ1's Avatar
I am having an issue with getting my car to start. I have a SL2 1996 engine that I blew. I replaced it with a 1998 SL2 engine. I have everything connected. It is turning over but won't start. I replaced wires, plugs, fuel rail and injectors. Everything is connected and the engine block is grounded. Anyone have any ideas? I appreciate the help!
Old Apr 4, 2007 | 04:22 PM
GarrenNatas's Avatar
Do you know if it runs off a different ECU?
Old Apr 4, 2007 | 04:58 PM
WiShJ1's Avatar
far as I know, it is on the same ECU... I did the research on it, and it is the same
Old Apr 4, 2007 | 06:58 PM
Then all I can think of is wiring or just a bad connection to a sensor...
Old Apr 4, 2007 | 11:09 PM
did you check for the basics (fuel and spark?)
Old Apr 5, 2007 | 02:53 PM
He said that everything was connected so I'll assume he knows something of cars... I was thinking it would be more along the lines of something he can't see...
Old Apr 5, 2007 | 03:02 PM
ducky's Avatar
1-As suggested, does fuel spray out from the fuel rail schrader valve (same as the tire valve)? Yes, continue otherwise troubleshoot fuel pump, fuse, and relay problems.
2-Remove the #2 and #4 coil wires, have someone crank the engine while you observe for sparks across the two coils. No, check again to be sure there are no sparks being generated. The lack of sparking would most likely be the fault of the crank position sensor (CPS). Try removing the other two coil wires to check for sparking across the coils. Still no spark would most likely mean a defective CPS. You should check and remove if necesary the coils for corrosion at the bases, sand down the corrosion on exposed metal including the mounting bolts. Lightly sand the coil towers too. Use a little dielectric grease on the plug boots to prevent future corrosion. Use a little regulargrease on the mounting bolts for corrosion prevention too. If you have spark you'll have to re-check all connections again. The CPS is above and behind the starter.
2001SaturnSL1
Dec 1, 2024 07:57 AM
terrybneal
Jul 29, 2015 09:52 AM
Merkle85
Jun 25, 2013 03:31 PM
drapain
May 7, 2012 01:09 AM
elkslayer69
Sep 29, 2005 06:25 AM
