*HELP* 1999 SL1 rear defrost not working
Please guys I need some expert advices to fix my rear defrost. I tried swapping the relay from the fuse box inside along with the two under the hood (all 3 are indentical). I also tried a different button from the junk yard. No luck. All the fuses from both fuse boxes either have no power or testing good. The amber light is not coming on when I press the button. I have also noticed that the chime from when I leave the lights on is not working. I have not looked at the back of the inside fuse box yet to look for melted connections. Any suggestions? TIA!
*EDIT* I can't figure out how to delete my post. I was able to fix the issue. As it turns out, the chime module was not inserted all the way. All good now!
harleypower69
Feb 20, 2021 06:45 AM
jhnbapst3
Nov 26, 2018 07:30 AM
