Trans quit
Old Sep 19, 2019 | 09:09 AM
steventech's Avatar
Default Trans quit
Transmission quit all of a sudden today at a stoplight. I’ve got no forward or reverse gears but the speedometer still works when you push the throttle. I did have the hard shift problem when the transmission was warm but, This failure happened with the transmission was still cool. Any ideas?
Old Sep 19, 2019 | 10:20 AM
I suspect a failed right front axle. The speedometer speed sensor reads from that side. Be careful park position will NOT prevent the car from rolling away.
Old Sep 19, 2019 | 01:01 PM
steventech's Avatar
I replaced both CV shafts less than a year ago. I have it on ramps and the rear wheels chocked, I looked at both axles while I had it in reverse and neither shaft was spinning. Aren’t the speed sensors on the hubs? So the shaft would have to spin to give a reading.?.
Old Sep 19, 2019 | 02:44 PM
steventech's Avatar
Inspected CV shaft on right side....it had popped out somehow(maybe I didn’t insert it all the way during replacement). Thank you 02 LW300 for pointing me in the right direction
Old Sep 19, 2019 | 10:42 PM
On my stick shift car the rf wheel speed sensor drives the speedo. On a non abs stick shift car there is only a rf sensor. All automatic l series cars use the output speed sensor on the 4t45 transmission for speedo. Glad it was an easy fix. I have exploded outer ends before on a turbo Diesel Audi we had 30 years ago. Big bang and the ***** hit the street!
Ohio_Guy
Jan 19, 2016 08:11 AM
Jdawg965
Jun 2, 2012 05:25 PM
dontknowwhat
Jul 4, 2009 10:11 PM
alstar80j
Mar 22, 2009 07:13 AM
brewcity scribe
Engine & Internal
Feb 5, 2008 06:28 PM
