2007 Ion 2 Stuck CV Axle
Old Nov 7, 2022 | 12:07 PM
Megs22's Avatar
Default 2007 Ion 2 Stuck CV Axle
I am replacing my CV axle and it will not come out! Any advice??
Old Nov 7, 2022 | 07:56 PM
oldmarine's Avatar
See if this video from YouTube helps
Old Nov 11, 2022 | 12:58 PM
Megs22's Avatar
Thank you for sharing! I watched the video and still can not get it out! The way it's set up, it is impossible for me to access the axle, especially with tools, from underneath and behind. I don't see a clip or anything that can be removed to release it either. I put the car in neutral and it seems like it wants to come out, but will not. I attempted to jiggle it back and forth and it turns to the right but not the left. This is driving me nuts. All of the videos I have watched make it looks so easy. The axles literally just pop out with a little pressure using a pry bar.
Old Nov 11, 2022 | 01:11 PM
oldmarine's Avatar
You are trying to remove the axle from the transmission, right? I was confused by the the statement "turns to the right but not the left". The axle is kept in position by a 'c' clip around the inner spline which snaps into a relief in the splined socket in the differential. See the replacement axle for example.
Please clarify what type transmission you have (automatic or manual) and which axle is giving you problems. Confirm that you have dismantled the front suspension far enough that the axle is free on the outboard end.
Old Nov 11, 2022 | 01:50 PM
Sometimes it takes more than a little pressure.
Old Nov 12, 2022 | 03:04 PM
Megs22's Avatar
Yes, I am trying to remove the axle from the transmission. After I put the car in neutral, I was able to turn the axle to the right.. for instance, as if I'm screwing it in.
The transmission is automatic. It is the front passenger side. The axle is free from the outboard end. I attached pics.
Attached Thumbnails 2007 Ion 2 Stuck CV Axle-pxl_20221112_201705379.jpg   2007 Ion 2 Stuck CV Axle-pxl_20221112_201730264.jpg   2007 Ion 2 Stuck CV Axle-pxl_20221112_201738558.jpg   2007 Ion 2 Stuck CV Axle-pxl_20221112_201748215.jpg   2007 Ion 2 Stuck CV Axle-pxl_20221112_201755730.jpg
Old Nov 12, 2022 | 03:10 PM
Megs22's Avatar
I, myself, have definitely put more than a little pressure!!! I actually hope I haven't damaged anything else in the process of trying to get it out! The videos I've seen, however, are a different story..
Old Nov 12, 2022 | 04:30 PM
oldmarine's Avatar
Good pictures! See this video of the passenger side axle being removed from a Chevy HHR (same setup as your Ion). According to RockAuto, your axle has a stub shaft at the inboard end. This is covered in the video. You will note in the video that the mechanic is using a pretty heavy hammer with considerable force to separate the components. So keep at it! Don't be afraid to whack it good! You'll get it done.
Old Nov 13, 2022 | 08:00 AM
Have you tried shoving it in and then pulling it out quickly? Sometimes this will help release the clip. I've never had that problem with any of my Mopars. BUT, I've never done one on a Saturn.
Ohio_Guy
Jan 19, 2016 08:11 AM
Howard_Woodard
May 2, 2014 07:10 AM
dj_ax
Feb 9, 2013 05:03 AM
autiger
Aug 10, 2012 09:17 AM
alstar80j
Mar 22, 2009 07:13 AM
