2004 Saturn Ion 3 setting 10 mo. Won’t start
Old Dec 12, 2020 | 08:40 AM
Jhunter69's Avatar
Default 2004 Saturn Ion 3 setting 10 mo. Won’t start
Purchased a 04 Saturn Ion 3 sedan that has not been started in 10 months. It is a very well taken care of car, one owner with all records from 04 until. 2019.. No major fixes, no major problems.. any Ideas where to start? I have read several threads on other site about start issues, which I need info on what to do first.. Jumpstarts will not engage nothing but the gauges and lights.. Just a click is all I get
Old Dec 13, 2020 | 12:42 AM
DropDead's Avatar
You check for codes?
Old Dec 13, 2020 | 02:22 AM
Bendix in starter may be hung up and not engaging flywheel properly.
Bang semi gently on the starter near the solenoid with a hammer or put a pipe against it if you cannot reach it and hit the pipe. Do not try to beat the crap out of it there is no need. If the car starts after that, then you may be able to get the starter to function properly from repeated use.
If that is in fact the issue.
If it is the issue, if you are impatient, then throw a new starter in it period but only after you have confirmed that is actually the issue. Shotgunning parts is expensive.
Was the vehicle running properly right before it was parked 10 months ago?
Old Dec 13, 2020 | 05:07 AM
Jhunter69's Avatar
I got the car Running, I want and bought a Duralast Gold 800 cold cranking amp battery and she fired rite up and Runs Smooth with no issues, Gonna now do all the normal maintenance of oil change fluids and all Thanks
Old Dec 13, 2020 | 11:25 AM
Make sure you have clean battery cable connections on both the positive and negative posts. I was gonna suggest the battery but haven't been on the forum for a few days. Today is the first time I've seen this post. Enjoy your Saturn.
Jhunter69
Dec 13, 2020 11:27 AM
dadinda
Jan 23, 2019 09:04 PM
tamyreaves@yahoo.com
Dec 11, 2018 02:34 PM
saturnvue04gal
Aug 20, 2017 08:47 PM
tikidude
Aug 30, 2014 05:04 PM
