Modified 1992 Saturn Trike Clutch
Old 10-19-2015, 06:41 PM
Handy1's Avatar
Default Modified 1992 Saturn Trike Clutch
A couple more pics of the clutch line modification. I ended up extending the length of the clutch hydraulic line. I removed the fittings out of a salvage clutch line. I silver soldered the ends into a section of brake line and then pressed sections of the original nylon line on to get the length I needed. They weren't kidding when they say you cant manually bleed the clutch slave cylinder. I picked up an old power bleeder and turned a aluminum cap with the fitting in it for the bleeder for the clutch master cylinder. I still took 50 LBS of pressure on the bleeder to get it bled out but I finally got it.
Attached Thumbnails Modified 1992 Saturn Trike  Clutch-img_0284_1.jpg   Modified 1992 Saturn Trike  Clutch-img_0285_1.jpg   Modified 1992 Saturn Trike  Clutch-img_0287_1.jpg   Modified 1992 Saturn Trike  Clutch-img_0289_1.jpg   Modified 1992 Saturn Trike  Clutch-img_0290_1.jpg
Old 10-19-2015, 08:47 PM
congrats on the slave bleed. Not many folks succeed
Handy1
10-19-2015 08:45 PM
Handy1
10-18-2015 09:06 PM
Handy1
10-16-2015 10:39 PM
RjION
10-16-2015 04:11 AM
2000saturnsl2
03-16-2008 04:28 PM
Quick Reply: Modified 1992 Saturn Trike Clutch
