no crank 06 ion
Old Oct 4, 2025 | 09:05 PM
randyboyd's Avatar
Default no crank 06 ion
my coolant fan went out and i replaced it afterward i still had codes for it it pulled diode out of wiper curcit to check and put it back in wrong spot one pin was in wiper and one pin was in fog light spot car died and wont crank checked all fuses all good .tried used bcm and ing switch same thing tryied secuity reset same thing feeling very stupid for causing this headache just want to be driving my great ion again.
Old Oct 4, 2025 | 11:28 PM
Wiper diode on 2.2 and 2.4 and fog light fuse are nowhere near each other in the UHJB.
So no clue what you're talking about.
Post a pic of your fuse box that shows what you did.
Security does not prevent cranking, only running.
Please answer the following questions:
Model
Mileage
Do wipers function?
Do fog lights function?
How did you test the wiper diode?
Whas the wiper diode good or bad?
Does the engine crank if you you short the starter terminals
Old Oct 6, 2025 | 08:42 PM
That's what I thought.
Old Oct 9, 2025 | 06:19 PM
randyboyd's Avatar
I put 1 spade of the diode in the right pin of fuse box and the other one to pin on the right of it that's when the diode melted and car died out would not crank after that does the ignition ground through ecm could I have brunt that up?
it is a 2006 135'000 miles on it randy great before that
Old Oct 9, 2025 | 07:13 PM
You came back, we will have to find the point of failure in you electrical system.
As Derf has already asked what works and what does not work.
We can dig into the schematics after you report what if anything still works.
Andy
Old Oct 9, 2025 | 07:24 PM
We can help, but you need to help also. Here is a link to the auto repair manuals online. I just looked at the fuse box and what the fuses do on your car.
Old Oct 10, 2025 | 12:47 AM
randyboyd's Avatar
Half of fuse box has no power like injectors and ignition but lights windows locks all still work
Old Oct 10, 2025 | 02:41 AM
Good to know, but not helpful for diagnostic attempts.
Last chance
Please Report:
  • which fuses and circuits do not have power.
  • Answers to my previously asked questions
  • A picture of the melted diode annotated to show which two terminals it was placed across and which direction the diode was placed in the circuit
Loube43
Aug 27, 2024 07:49 AM
mtb5e7bgj@mozmail.com
Mar 16, 2024 04:14 PM
tkneky
Nov 26, 2022 09:27 AM
Cory
Aug 14, 2021 07:49 AM
Ascalon
Dec 10, 2019 03:14 AM
