sc2 back up lights not working
Old Jun 10, 2005 | 01:12 AM
sdntive's Avatar
I just replced both back up light bulbs on my 1995 sc2 because they did not work (I dont think they ever worked), at the bulb housing i am getting 12 volts in each but when I put in a bulb, it did not light up and the other housing reads 0 volts, when i removed the light bulb thehousing with thevolt meter reads 6 volts, I tried several sets of bulbs and they never lit up. It has a manual transmissionand if anyone has any suggestions it would be helpful.
Old Jun 13, 2005 | 03:05 PM
gytre1's Avatar
if you own a saturn.. i feel sad for you guys. GET A NEW f**kING CAR! THEYRE JUNK
Old Jul 13, 2005 | 07:19 PM
ottjoe88's Avatar
the light bulb sockets may just have a loose connection, I had the same problem with mine . I cleaned out the sockets and they worked fine after that
Old Jul 28, 2006 | 06:38 PM
umbcmatt's Avatar
i know on my manual '92 SC there is a back up switch up on the engine that I had to replace. It's about $13.00 compared to the $150 a mechanic wanted to fix my back up light problem. It's discussed on a few other things here and in the repair books.. I believe autozone's web pages...(look up the part and then "identify part location") will show you where it is... took 5 minutes to fix!!!
GETURDONE
Jun 21, 2024 07:25 PM
Kasper_B
May 22, 2019 01:14 PM
saturns_moon
Jan 24, 2014 11:20 AM
titan318i
Sep 24, 2010 02:56 PM
cadman33619
Oct 7, 2009 07:04 PM
