@2002-2003 l200 Shift indicator lights wiring diagram
Old 09-10-2018, 11:28 AM
thebiglar's Avatar
Default @2002-2003 l200 Shift indicator lights wiring diagram
Would anyone have the wiring diagram for the shift indicator lights PRND123 on a L200 automatic console shifter. There are 8 wires on the plug that plugs into the light module. I am assuming that one is a ground and the other 7 go to each shift indicator light. I have tested wires with a meter for continunity but can not seem to figure out which is which is which. I am trying to use this in a console on a street rod I am building. Any help is appreciated.
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-img_3444.jpg   @2002-2003 l200 Shift indicator lights wiring diagram-img_3446.jpg   @2002-2003 l200 Shift indicator lights wiring diagram-img_3445.jpg
Old 09-11-2018, 10:45 PM
I’m working on this for you
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-f3292b93-afaa-4aa3-b626-ae66d7997512.jpeg
Old 09-11-2018, 11:47 PM
It is actually a module and I would really have to want to know how it works to spend more time. I would power it, ground it and power the lighting and play with the other 4 one at a time and see what lights up.
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-92d3f0ea-7b46-4ad8-a7b2-8e671a8f878a.jpeg   @2002-2003 l200 Shift indicator lights wiring diagram-15fdf5de-95e3-4698-bde2-9dad31fe1dd1.jpeg
Old 09-12-2018, 08:25 AM
thebiglar's Avatar
Default Very Helpful
This helps a lot. By what I see here the black wire is the ground for the module and the other 7 wires would go to each of the 7 indicator lights. So if I use a battery charger as power source and ground the black wire each light should light up as I touch them to power. I have a sender that will hook to the trans linkage and will power each light as gear is selected, so I have that side covered to get power to the lights when this is finished. Just have to get the lights working. I will do some more testing and let you know how I make out. Thank you very much.
Kasper_B
05-22-2019 01:14 PM
mikenic
06-24-2018 09:23 PM
saturns_moon
01-24-2014 11:20 AM
cliffsongs
01-13-2012 06:53 AM
LmyVue
10-09-2008 10:23 AM
Quick Reply: @2002-2003 l200 Shift indicator lights wiring diagram
