Question
Old 02-23-2019, 11:16 PM
Fastballkid69's Avatar
Default Question
I have a vibrate after I put a new center bearing in the driveshaft it's awd and also did the u joints . is this normal . my car is a 04 saturn vue
Old 02-24-2019, 10:51 AM
No, it shoud not vibrate. Have you ever repaired a driveshaft before?
Old 02-24-2019, 06:30 PM
Default Yes I have
I throught it maybe just something else idk I can feel it when sitting in my driver seat it not bad
Old 02-24-2019, 07:53 PM
Did it vibrate before you worked on the driveshaft? You can remove the driveshaft and drive your Vue as a front wheel drive I believe.
Old 02-24-2019, 08:10 PM
The bearing was shot so it was not all brand new . so idk
Old 02-25-2019, 07:54 AM
Pull it out and rotate it a 1/2 turn (180 degrees) and reinstall it. Maybe it's not in the right position?
Old 02-28-2019, 04:45 PM
I will have to try that .
It don't vibrate b4 just couldn't tell because the center bear . and there no marks for the driveshaft to line up . i should of mark it but didn't think b4 Hand just wanted to fix it
Old 02-28-2019, 05:57 PM
All the u-joints should line up if you see what I mean. I don’t know if the center yoke has a master spline on your car. If there is a master spline the yoke will only go on the splines one way. On your original posting you were looking for the snap ring the holds the driveline together. That is where most drivelines shake if you misaligned the splines. As long as you did not bend the tubes when replacing the joints.
Old 01-15-2021, 07:54 PM
That could be the growling I hear in the morning as well as the clunking I hear after it's warmed up! It's been stumping every mechanic!
Old 01-16-2021, 09:25 PM
Every mechanic but Andy.
dvalent
06-03-2018 06:24 PM
RedSL2
07-27-2009 05:59 PM
RedSL2
07-27-2009 05:49 PM
RedSL2
07-26-2009 12:08 AM
RedSL2
07-22-2009 12:26 AM
Quick Reply: Question
