Pulsing Electric??
Old Yesterday | 09:23 AM
psdrummin's Avatar
Default Pulsing Electric??
I have a 2007 Saturn Vue V6 AWD with 153,000 miles. It started to randomly start faintly 'pulsing' or 'flashing' on the dash along with a battery light that flashes on and off but never stays on.
Again, this will happen 1 out of every 5 times when I start. Sometimes it will keep doing this as I drive and sometimes it will disappears as driving.
I've attached a 10 sec video to show what it is doing.
I have never lost any battery or had any issues starting the car. Triple AAA came out and tested my battery and said it's perfect. Anyone seen this before??
I'm gonna take it in but was just curious...
File Type: wmv
Old Yesterday | 05:04 PM
Voltage regulator? Alternator?
That's without saying the video which won't load for me
Old Yesterday | 06:05 PM
psdrummin's Avatar
Hmmm.. here's a YouTube link
Old Yesterday | 08:02 PM
grcauto8453's Avatar
Can verify AC is getting through with a meter or turn the lights on high fan at full radio on etc. Load the charging circuit and see if the pulses get more pronounced. If so, you have a bad rectifier.
Old Yesterday | 08:41 PM
psdrummin's Avatar
Would it be a rectifier if the battery never gets weak??
Old Yesterday | 11:30 PM
A battery can be fine all the time and diodes can go bad. It's more likely that a bad alternator will kill it.
Old Today | 05:20 AM
Research says this vehicle has a smart charging system, controlled by the ECM. There should be a multi wire connector plugged into the back of the alternator. Check for corrosion/damaged wiring. The rhythmic blinking may indicate a communications error between the ECM and the alternator, or some type of misbehavior of the alternator when commanded by the ECU
biocat
Aug 15, 2024 12:15 PM
pdaly28
Oct 6, 2023 03:23 PM
Jessii87
Apr 27, 2020 10:44 PM
jimmydon
Jan 25, 2009 08:12 PM
conniemay38135
Nov 25, 2008 08:04 PM
