Thermostat questions...Need help
Old Aug 30, 2009 | 01:20 PM
Jonnysig's Avatar
Default Thermostat questions...Need help
My Temp gauge in my 97 SL1 is hanging at Cold. Wont go above C. Troubleshooting tree said "thermostat stuck open" so I Changed the thermostat yesterday and it still hangs up at Cold.
Troubleshooting tree said to feel the main coolant line running to thermostat and if it is hot it is working as normal. Felt pretty hot to me. I really dont think I got a bad thermostat as this is the 2nd one I've changed. Still got the first one. Someone said you can put it in boiling water to make sure its working as advertised. This true?? Also...any other suggestions? Could my gauge be toast???
Old Aug 30, 2009 | 07:04 PM
saturnsdn's Avatar
I've heard the same thing about the boiling water "trick" but never tired it. it could be your gauge but have you tired changing your ects?
Old Sep 14, 2009 | 09:40 PM
PdPuNOme's Avatar
Default answer for temp guage
Your temp guage is not moving because you need to replace your cooling temp sensor $10 at parts store $35 for oem at saturn does the trick.
Old Sep 16, 2009 | 07:25 PM
+1 ects
AjayIV
Dec 12, 2013 11:40 AM
Carterx
Dec 13, 2010 12:13 PM
98sc2pcfl
Mar 13, 2009 09:25 PM
awesome_7
Mar 11, 2008 07:53 AM
Carrier999
Jan 20, 2008 09:53 PM
