starting issue 97 sl2
Old Dec 25, 2008 | 11:04 PM
gixxersac's Avatar
The car wont turn over, all power works. Im able to start the car by push starting it and also arcing the two leads on the starter. I replaced the starter-relay under the dash, bypassed the clutch saftey switch car still wont start/turn over. any ideas??
Old Dec 26, 2008 | 12:30 PM
Gixxersac ... Check on each of these items:
Underhood Junction Block IGN3 fuse 30amp.
RKE module (if remote keyless entry is present)
Defective ignition switch
Good luck with your search ...
Old Dec 28, 2008 | 07:43 PM
RC1488's Avatar
Define turn over. It wont crank? Or it will crank but not start up.
Cranks but doesnt start:
The ''97 year has a bad check valve in the pump. This allows pressure to fall when the car is shut off at the fuel rail. Easy fix. Put the key in RUN for 2 seconds untill the Humm of the fuel pump stops. Then start the car. Should start right up.
Does not crank: Electrical issue. Either security, or something with the ignition wiring.
chblanx
Jun 7, 2012 05:11 PM
Hbal
May 11, 2011 06:43 AM
masterm6
Mar 29, 2011 11:59 PM
allen405
Apr 8, 2007 11:08 AM
mrtigger
Oct 30, 2005 01:29 PM
