The car wont turn over, all power works. Im able to start the car by push starting it and also arcing the two leads on the starter. I replaced the starter-relay under the dash, bypassed the clutch saftey switch car still wont start/turn over. any ideas?? |
Gixxersac ... Check on each of these items:
Underhood Junction Block IGN3 fuse 30amp. RKE module (if remote keyless entry is present) Defective ignition switch Good luck with your search ... |
Define turn over. It wont crank? Or it will crank but not start up.
Cranks but doesnt start: The ''97 year has a bad check valve in the pump. This allows pressure to fall when the car is shut off at the fuel rail. Easy fix. Put the key in RUN for 2 seconds untill the Humm of the fuel pump stops. Then start the car. Should start right up. Does not crank: Electrical issue. Either security, or something with the ignition wiring. |
