Service (wrench) light
Old Dec 31, 2013 | 11:35 AM
raddatzjos's Avatar
So I have been misinformed, thank you for correcting that.
When you say EI module, can I safely assume you refer to what I've always called the ignition module beneath the coil packs? We replaced that module when I bought the car due to lack of spark on two cylinders. I had one from an SOHC engine laying around from work on my SL1, and my dad assumed they would be nearly identical despite this being a DOHC engine. Could this be the culprit?
When I bought this wagon, we had to overhaul the engine to fix a lack of compression on cylinder 3 caused by overheated and warped valves. When we did this, we replaced all four spark plugs due various issues each of the former ones had, so I doubt those would be the culprit. I also doubt remaining ice or water as we had two days of nearly 40 degree weather and I drove the car at least 30 miles each day, as well as 60 miles the following day.
The efficiency of this car is definitely not what I expected too. I use an app on my phone to keep a running tally of fuel efficiency and maintenance costs, and looking back, I've gotten mostly low 30's and high 20's for mileage. Definitely not what I expected, especially considering my SL1 never got below 30 unless something was wrong with the engine.
pb1968
18
Apr 13, 2013 10:12 AM
mrtweaver
Nov 20, 2012 04:51 PM
Octavious
Mar 16, 2012 08:19 PM
ericsyzf
Jan 5, 2007 10:17 AM
tommy7133
Feb 25, 2006 12:35 AM
