Price for left CV joint replacement
Old Dec 30, 2008 | 02:12 PM
autiger's Avatar
My left cv joint has started to click in my 2001 sl1. 111K miles on it. No tear/ leak in the boot. Can it safely be repacked or does the CV joint need to be replaced? How much should I expect to pay a mechanic for labor? [img]smileys/smiley5.gif[/img]
Old Dec 30, 2008 | 02:42 PM
Low Saturn's Avatar
Much easier to just replace the axle assembly. Its a very easy 15 minute job. But a shop will charge at least an hour for labor plus over charge for the parts. So you''re looking at $250-$350 for a replacement. Or less than $100 to do it yourself.
Old Jan 2, 2009 | 05:10 PM
RC1488's Avatar
+1. Do it yourself
Old Aug 9, 2012 | 11:41 PM
timmerz's Avatar
Toby, yours is the first one I've ever heard of that went bad...I'm sure it happens, no vehicle is perfect, but they did such a great job of protecting them I just haven't heard of any going bad before...
Old Aug 10, 2012 | 09:17 AM
I've had a couple go bad on me, but I attribute it to the fact that the boots were torn. In any event, if you're going to have it done, think seriously about having your existing shafts rebuilt. Pricing to rebuild will be about the same as buying after-market replacements, but there's a problem with some of the after-market units ... the over-all assembled dimension is not the same as the OEM shafts, and could cause you problems down the road. Just a personal opinion here ...........
Howard_Woodard
May 2, 2014 07:10 AM
alstar80j
Mar 22, 2009 07:13 AM
jcm22
Jul 14, 2007 09:20 AM
dgi007
Audio/Visual Electronics
Apr 2, 2006 05:08 AM
