Power Mirror not working
Old Jan 9, 2010 | 04:07 PM
jkircher1's Avatar
Default Power Mirror not working
The driver side mirror was hit and snapped off in a recent cold spell. thus the mirror was replaced. 3 days after replacing the mirror stopped working and the open trunk light goes on when the mirror control is tried. any ideas would be great. thanks
Old Jan 9, 2010 | 04:24 PM
Ok so
the mirror no longer works
or
connection is no longer good
or
the switch has gone bad
the car is to far from me to check it out so I guess you'll need to do that. Then again maybe you should have someone that has an idea how things work do it for you.
Old Jan 9, 2010 | 10:17 PM
are trunk open light and power mirror on the same circuit?
Old Jan 10, 2010 | 10:39 AM
jkircher1's Avatar
do not know, just find it odd that after putting the new mirror on, it worked and then 3 days later it stopped and whenever you try using the power mirror the trunk open light flashes. I checked the fuses and they where all fine. I think it is some sort of error code but can not find what the code means.since they are linked I would assume they are on the same circuit.
Old Jan 10, 2010 | 03:45 PM
wiring issue? -- maybe chafed insulation which is now shorting on something?
Please post diag code here and we will try to help you diagnose
Old Jan 11, 2010 | 01:13 PM
jkircher1's Avatar
found the problem. I removed the mirror, and discovered that the wire had slipped under one of the bolts, and the steal of the door which ended up severing the wire (thus the mirror stopped working) the trunk indicator light must have been on the same circuit as that was how the car was responding. So the fuse is located in the passenger side fuse panel and was the left body 10a fuse. when I originally checked the fuses I was not able to check the left or right body fuse you have to pull all of the fuses and the two relays in order to get the fuse puller on the fuse and pull it figures the two I could not get at would be the one that was blown. Thanks for your advice.
Old Jan 12, 2010 | 06:12 AM
You're quite welcome. Glad you are once again fully mirrorized and un-trunk blinked.
j_dobso2
Nov 16, 2020 10:41 PM
DailyPlanet
Jun 29, 2014 07:24 PM
john doe
Apr 19, 2013 08:28 PM
dlsgap
Apr 28, 2011 07:38 PM
pester
Sep 5, 2008 03:25 PM
