odd starting issue
Old Jun 14, 2018 | 03:49 PM
notny41's Avatar
Default odd starting issue
1999 SL2 manual trans
just bought the car. When the car is warm almost every time I go to start it I push the clutch in and turn the key and it just cranks but no sign of life til I switch the key off and try to start again. Then it starts right up.
almost seems like a security system is cutting ignotion the first time I crank it.
​​​​​​​car runs great after it starts.
anyone else ever experience this?
Old Jun 14, 2018 | 10:23 PM
Probably fuel pressure bleed off between trips.
Turn key to on, count to 4,5,6. Then crank. You should be able to find a time interval that works for you.
If that doesn't work for you we can investigate further.
notny41
Apr 20, 2019 09:50 PM
blaisa
Apr 21, 2018 10:12 AM
SSim
Mar 3, 2011 09:42 PM
gixxersac
Dec 28, 2008 07:43 PM
dana_gammon
Engine & Internal
Nov 2, 2007 06:01 PM
