Fan Stopped Working
Old Jul 10, 2007 | 07:45 AM
gbelous's Avatar
When I changed the radiator I removed the fan and after I put everything back I noticed it didn't work anymore. All the wires are hooked up and everything is back in place, so anyone know what is wrong with it? Do I just need to replace the fan motor or the entire assembly?
Another thought....at what temp does the fan usually turn on? I let the car idle for about 10-15 min and the temp guage was just under 1/2. Did I just not let it get hot enough?
Edited by: gbelous
Old Jul 10, 2007 | 01:21 PM
ducky's Avatar
You could try wiring the fan directly to the battery or just wait for the temperature gauge to go to 3/4 or just before the red line before the fan will turn on. Remember, you just changed the radiator so the car is already running cooler and will need to be driven a bit before the temps come up to operating temperature. On cars with a/c you can switch on the a/c and the fan should come on immediately.
Old Jul 10, 2007 | 01:44 PM
gbelous's Avatar
okay, ill try the ac thing and see if it works. thanks for the tip, i wouldnt have thought of that.
sybd93
Jun 9, 2011 05:40 PM
Surkis
Jun 4, 2010 10:40 PM
Seth K
Nov 10, 2009 09:27 PM
Dale002
Apr 18, 2008 02:38 PM
MLmom
Apr 8, 2008 03:08 PM
