engine mount repeated failure 1997 SW2
Old Sep 25, 2007 | 06:51 PM
gregorye70's Avatar
I have owned a 1997 Saturn SW2for 4 years and the upper left hand side (as you are in front of the car looking at it) engine mount has worn out 3 times. The rubber underneath the upside down U-shaped bracket eventually shrinks away from the top of that bracket and allows excessive vibration in the car.
Anyone else have this problem and know a solution other than replacing the mount each time at a cost of $67?
-thanks
Old Sep 25, 2007 | 07:11 PM
Buy the mount from the dealer
Old Sep 26, 2007 | 11:09 PM
bottlecap's Avatar
when ever i have had worn mounts like this in the past i i use a little urathan glue to fill in the gap give it a day or two to cure and it will never go bad again.
Does any one make an upgraded motor mount for that spot?
Old Sep 27, 2007 | 08:19 AM
01dbsc2's Avatar
Try SDA, he sells poly mounts. LINK
Old Sep 27, 2007 | 06:58 PM
bottlecap's Avatar
sweet link thanks
JDC
Jun 9, 2014 09:44 AM
st1tchy
Mar 13, 2014 11:31 AM
mom7x
Aug 28, 2007 05:42 PM
getsch1
Dec 6, 2005 02:56 AM
BOBWAN
Nov 27, 2005 02:16 PM
