I have owned a 1997 Saturn SW2for 4 years and the upper left hand side (as you are in front of the car looking at it) engine mount has worn out 3 times. The rubber underneath the upside down U-shaped bracket eventually shrinks away from the top of that bracket and allows excessive vibration in the car. Anyone else have this problem and know a solution other than replacing the mount each time at a cost of $67? -thanks |
Buy the mount from the dealer
when ever i have had worn mounts like this in the past i i use a little urathan glue to fill in the gap give it a day or two to cure and it will never go bad again. Does any one make an upgraded motor mount for that spot? |
Try SDA, he sells poly mounts. LINK
sweet link thanks
