Engine mount replacement
Old Nov 18, 2005 | 05:58 PM
BOBWAN's Avatar
Problem:One of my engine mounts is worn and needs to be replaced. I get
a slight vibration when i am idling. I had a a dealership look at it
and they said it is the T/A engine mount. I dont know which one that
is. Is there a way I can replace that at home without taking it
somewhere?
Old Nov 27, 2005 | 04:54 AM
rick_ryder's Avatar
Easy to replace all you need is a floor jack, a small piece of two by four and a 15 mm socket. Place the wood flat on top of the jack to distribute the weight and jackon the oil pan. Not much just enough to see the motor start to rise about 1/4 in. This takes the load off the top mount.The mount can now be removed five 15 mm nuts. Mount is at the end of the valve cover above the drive belt. When dropping the new mount in you may have to jack the motor a little to get the holes to line up due to sag from the old mount. Thats about it, bolt it on, drop out the jack and your done.
Old Nov 27, 2005 | 02:16 PM
BOBWAN's Avatar
thanks i was sure there had to be a way to do it easy rather than paying almost 300 dollars to have it done
gregorye70
Sep 27, 2007 06:58 PM
jamienfld
Aug 20, 2007 01:53 PM
jamienfld
Sep 2, 2006 11:35 PM
paulorlo
Jan 17, 2006 01:13 AM
getsch1
Dec 6, 2005 02:56 AM
