99 SL2 Vibration/rattle & P0440 code
Old Apr 1, 2011 | 08:11 PM
shadetreemech's Avatar
Default 99 SL2 Vibration/rattle & P0440 code
Engine runs good but has a pretty bad rattle, especially with the a/c on. Suspect it could be the tensioner, but it seems ok with the belt off. Don't think its the chain since recently had off and doesn't appear stretched or worn. Also have general vibration, but I've checked the top and transmission motor mounts and they do not appear to be bad. Final problem is trouble code P0440 which keeps coming back after only one drive cycle. Cleaned EGR valve twice but didn't solve problem.
Old Apr 1, 2011 | 10:44 PM
Top engine mount ................
Old Apr 1, 2011 | 10:50 PM
General Vibration
Replace top pass motor mount for starters (especially if you never have)--these wear out with time -- these engines shake a whole hell of a lot. Be sure to use new mounting studs and do not overtorque or they will twist right off.
Other vibration -- not enough info for me to do anything other than guess at. Is SES light on?
P0440
nice little thread that may or may not help you troubleshoot:
http://www.saturnfans.com/forums/sho...ighlight=p0440
109 other threads (some likely related to your vintage of S car) available at
http://www.saturnfans.com/forums/sea...archid=4300493
enjoy and let us know what it was
krazy Dan
Apr 15, 2017 11:08 AM
zero467
Mar 8, 2013 04:24 PM
latestgood
May 5, 2008 09:20 AM
rabobanks
Oct 11, 2007 10:31 AM
mikes 1994 z28
Aug 9, 2006 09:08 AM
