95 Saturn SL won't turn over!?
Old Jun 9, 2009 | 02:21 PM
b4ugobye's Avatar
Thumbs up
just a follow up on my 99 saturn... I changed the ECTS and right off the bat i notice idle is 200 rpm lower and seems to run smoother. I havent taken it for a drive yet, but I think this might have been my issue... thanks guys for the help, without your help, I might have spent hundreds of dollars for a $10 problem. Thanks again!
Old Jun 9, 2009 | 03:07 PM
Glad you are back on the road -- just be sure to reconnect your wiring for the radiator cooling fan ....
Old Jun 11, 2009 | 12:04 PM
olstoro's Avatar
Well I replaced the ECTS and temp sensor behind it and the car still won't start!
Does anyone recomend checking anything else?
Old Jun 12, 2009 | 12:42 AM
any codes stored?
Old Jun 22, 2009 | 02:33 PM
olstoro's Avatar
Ok.. after replacing both the Ects, the other coolant sensor, cleaning the throttle body out really well and sticking a wrench into it to keep it open, it finally started.
Now the cooling fan never seems to come on, the car does not start back up until it has cooled back down... I tried the ac trick that I read in another post and the fan does not come on! I checked all fuses and wires going to it.... next i'm going to use a jumper wire from the battery directly to the fan and do the same for the ground.
I only let it run long enough to let the temp guage go half way.
Also when it's running it still idles high and low and sometimes sounds like it wants to die.
Thanks again everyone.
Old Jun 22, 2009 | 03:43 PM
budsjlm's Avatar
well i had issues with my fans and derf informed me that these s cars the fans dont kick on untill the third line did you replace the leads to your ects?
Old Jun 22, 2009 | 03:46 PM
budsjlm's Avatar
also u said your fan wires were cut befor and you fixed them i would sugest pulling a part your fix and jusf see if they work and if they do id say replce the relay
Rizzu7
Feb 19, 2013 12:28 PM
Jpete
Dec 14, 2009 10:21 PM
ford88mustang
Nov 15, 2009 07:17 AM
Kipp21
Jun 21, 2009 07:26 PM
Jada
May 23, 2008 03:14 PM
