2000 sl drops engine response
I have a 2000 Saturn sl and I'm having a big problem... at random my engine will become unresponsive to my gas pedal... I can start it right up every time no prob no hesitation at all then as I'm driving ithe rpms will drop to idle and I can put my foot to the floor with nothing from the engine... let it run for a few min then I can drive right off again...for a while....till it happens again.
Changed the fuel filter, used HEET, new crankshaft sensor, engine was rebuild along with the trany not too long ago...
2000 Saturn SL 5spd stick, everything stock 150k
Throw any ideas I am straight out of them.
Thanks
-Trevor
Thanks
-Trevor
When was the last time the fuel filter was changed? Maybe an intermittent clog that is severely restricting fuel flow
or
the exact opposite --
too much fuel (fuel pressure regulator)
What's the fuel pressure on the fuel rail under the hood?
or
Changed the fuel filter turned out the pump was on its way out so it would only give enough fuel to keep running at idle. When I checked the fuel coming out of the lines it was barely drizzling and stopped completely after a few seconds.
Hmmmm -- One would have thought a pressure reading would have found sumthin' like this,
I wonder how many of us do not have a pressure gauge for fuel presssure?
I never owned one for carbureted cars and did not buy one for my own use until I actually built a fuel injection conversion for an I-6 engine in a car I still own.
It started loosing fuel pumps and that convinced me to buy a pressure gauge for fuel injection.
For carburetors, I use a clear glass in line fuel line filter that I can insert in the line and watch the fuel flow through it.
I keep that as a diagnostic tool.
But I have used the Fuel injection fuel pressure gauge quite often.
I am trying to justify the purchase of a code reader at the present.
I still do not have one, but for the most part, I have not really needed one yet.
fordman
Dec 30, 2012 01:44 PM
