1995 sl1 brake problem
Old 03-28-2008, 11:25 AM
seagrave100's Avatar
I have 1995 sl1 with abs. It has had a mushy pedal for a while and i finally got around to changing the master. Bench bled the master and bled the absand the front wheels. When we tried to do the back there is no fluid or air. With the pedal depressed the wheels still spin freely. The e brake works fine and the wheels stop. We then removed brake line to rr at the abs pump and no fluid comes out when you depress the brake. I am under the impression that abs pump is bad. Any sugestions would be greatly appreciated
p.s. first time using a forum thanks
joe
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old 03-29-2008, 08:37 PM
Low Saturn's Avatar
Did you put the solenoids into the home position before bleeding the lines?
Michelle100
06-03-2010 07:01 AM
Gerard3906
11-06-2009 05:18 PM
Akramer
05-11-2009 07:42 AM
murcielago543
05-21-2008 09:24 AM
duganator
08-09-2007 10:44 PM
Quick Reply: 1995 sl1 brake problem
