1995 Saturn not starting.everything is good except fuel system.how do you check?
Old May 1, 2018 | 04:02 PM
James Overbeek's Avatar
Default 1995 Saturn not starting.everything is good except fuel system.how do you check?
How do you check Fu El system on 95 Saturn
Old May 2, 2018 | 12:00 AM
Moved to S series section from Engine/Internal (?????)
1)Check fuel pump fuse
2)Check Fuel Injector fuse.
3)Check fuel pump relay
Turn key to on. You should hear a quiet hum for about three seconds, then a distinct "click."
This is the fuel pump relay being engaged to prime the fuel system. The click is when the relay opens.
If you don't hear a hum and a click, your fuel pump is not being energized. The fuel pump relay must be closed for current to reach the fuel pump.
So if no hum, no click, fuel pump not energized. But Why NOT?
Multiple answers to that question.
Check the easy stuff above first
buftfan
Mar 31, 2018 07:40 PM
Galkaman
Sep 6, 2013 07:23 AM
tzent
May 31, 2008 06:03 PM
SL2 pirate
May 9, 2008 09:33 AM
trysten
Mar 5, 2007 07:33 PM
