97 sc1 i`ve tried everything(help)
Old May 27, 2008 | 09:05 PM
tzent's Avatar
ok the car was smoking (alot) and ruff idle once warm.i did ects,put in 2 new valves,new plugs,changed oil & filter,did good for about 2 weeks,then started again!!!!!!new pcm(junkyard),knocked out catalytic conv,headgasket,egr..my guess is that its getting too much fuel and mixing with oil,then causing smoke.no codes !!someone please help ..
Edited by: sw2cam
Old May 28, 2008 | 12:18 PM
Low Saturn's Avatar
What color is the smoke?
Old May 29, 2008 | 12:08 AM
tzent's Avatar
grey/blueish i forgot to mention this is a sohc.
Edited by: sw2cam
Old May 29, 2008 | 09:16 AM
Low Saturn's Avatar
Those are known to have the heads crack.
Old May 29, 2008 | 12:59 PM
tzent's Avatar
wouldnt ther be antifreez in the oil or visa versa?
Edited by: sw2cam
Old May 31, 2008 | 06:03 PM
tzent's Avatar
all of the plugs are wet..and it revoir is staying full?do you think its the fuel regulator/and where is it located?or any other suggestions?
SL2 pirate
May 9, 2008 09:33 AM
Shadowman750
Mar 28, 2008 10:50 AM
trysten
Mar 5, 2007 07:33 PM
CoastGuardGuy
Jun 27, 2006 01:25 AM
