1994 SL2 Odometer
Old Aug 22, 2013 | 10:19 AM
Joebeeker's Avatar
Default 1994 SL2 Odometer
My 1994 SL2 odometer has been working intermittently and I just lately have gotten around to investigating the problem.
I have had problems in the past and the red gears have been replaced all ready.
What I need this time is to test the odometer on a bench set up to eliminate or isolate the problem.
There is a three prong connection on the odometer assembly. I need to know what voltages go to each of the pins so I can test the assembly then install in back into the display cluster and then test again.
Thanks in advance...
Joebeeker
Old Aug 22, 2013 | 11:52 AM
Is it just the odometer portion of the gauge that is failing, or is the speedometer messed up too ??
Old Aug 22, 2013 | 04:44 PM
Joebeeker's Avatar
The speedometer works along with everything else except the temp gage (I am working on that also).
The only othe problem I am having is that the whitish plastic case is very brittle from heat exposure from the windshield I have to be very careful work on the unit.
Joebeeker
Old Aug 22, 2013 | 08:19 PM
94s had two temp sensors. A 1 wire sensor in the head that drives the dash gauge and a 2 wire sensor that feeds info to the pcm
Do you get heat in the winter and or does it overheat?
Old Aug 26, 2013 | 05:19 PM
Joebeeker's Avatar
About the temp gage...yes I get heat in the winter, I don't get a over temp light.
Where is the wire located in the head for the temp gage?
Thanks in advance..
Joebeeker
Old Aug 26, 2013 | 05:22 PM
On the driver's side of the engine, below where the upper radiator hose is connected. There are two sensors located there. You are interested in the sensor with only one wire connected to it (this is the temp gauge sensor)
Old Aug 26, 2013 | 08:21 PM
Joebeeker's Avatar
I FOUND IT.....I looked on the right side of the engine and what did I find....a broken green wire. So after I finish up the odometer repairs I will fix that wire and maybe get the gage to work.
What I didn't tell everyone I am the original owner of my 94 Sl2 and have about 270,000 miles on it...
Thank you all for yor help.
Joebeeker
Old Aug 27, 2013 | 11:21 AM
Joebeeker's Avatar
Last update...the green wire to the temp sensor complete and the gage works.
The reason the wire was broken was something was trying to build a nest in my engine compartment between the battery and fender. I cleaned the remains out and checked for other damage-none..
Thank for all your help
Old Aug 27, 2013 | 12:49 PM
Glad to hear you are back on the road, and running well -- congratulations
rytomi
Nov 14, 2014 07:51 PM
Joebeeker
Aug 29, 2013 05:30 PM
juggalo2929
Feb 25, 2007 04:32 PM
saturn28027
Oct 9, 2006 12:45 AM
ray3483
Mar 15, 2006 12:03 PM
