Saturn L300, what is this?
There is a black box directly attached fore of the battery it had a chunk taken out and i know it got wet. I need to know what it is but cant find anything on it. I know it got wet a a while back then it went crazy (wipers, lights, locks, horn and everything else going off) and it has sat ever since. recently I jumped it so it could run and get all the bad gas out and it got stuck in park with a security warning but after disconnecting the battery it went away. Also before the security warning came up the tachometer stopped working but the engine was still running. It didn't go crazy again but I need to know what that chip is and how much it will cost. (2002 Saturn L-300 4 door v6)
Well the temp gauge is pegged out and the idiot light was on light so it makes sense. I got it out today and found a blown fuse (i believe it was ignition 3) and replaced it. Then put new gas, washed it, and put some fuel injector cleaner in it. It ran ok but when i got home i checked the fuse boxes on the inside and when i went to open the driver side one the car flickered and went haywire like the first time it got wet. The tach died, the dash and dome lights flickered and went out along with the service soon and abs light coming on. In the passenger side the door locks fuse was blown and I replaced it. The security light came on and it was stuck in park. I unplugged the battery to reset it then jumped it again. The security light was still on but it went in gear and i drove it into the garage. Any idea on the cost of the part?
I would source a used one from a wrecking yard. Should fit all L series 2000-05. It sounds like your car may have the incorrect headlight switch also. The 02 switch does not have an off position. It has auto, park and on. I bought an 02 with an 01 switch and it had lots of flickering lights and clicking relays until corrected. You need a good battery for any further diagnosis, jumping a dead battery just won’t get it.
Originally Posted by Emb410
....my service soon light is on
That would have been nice to know from the get-go.
REPLACE YOUR BATTERY like the man said.
Go get the codes read for free at Autozone or similar FOR FREE --they usually lead you to the source of problems. Post as Pxxxx .
You posted to this site for advice.
You were given information and advice.
You chose to ignore the advice.
If you continue to ignore the advice we're providing, there's no point in us trying to help you to solve issues with your vehicle.
No, I'm not being arrogant and holier than thou; I'm simply saying you asked for our advice but you won't follow it.
If you don't plan on following our advice, why are you seeking it?
Please get the codes read, and post them and get a new battery before asking for more help, because there's nothing more we can do for you until you do.
Your choice
