03 Saturn l300
Old Jan 8, 2018 | 05:52 PM
timgasaway's Avatar
Default 03 Saturn l300
I live in Indiana my Saturn won't pass code reads po455 could someone tell me where the can is so I can check the hoses and lines so I can have my car back it's been ,2 months with out it it's not in the back of the car that I have seen I thank you for all your help I'm new on here so bear with me on sending or texting this to anyone
Old Jan 8, 2018 | 07:47 PM
Well the canister is on top of the fuel tank, that’s the bad news. The good news is the evap problems are usually the fuel filler pipe is rusted through. If you remove the rr inner fender you can inspect and or repair the filler pipes. There is a solenoid up near the cap but the tubes rust through and do not hold vacuum for the evap test. If the small overflow pipe is bad just replace it with fuel hose. Same with the large fill pipe. Auto parts stores sell fuel fill hose just measure the outside diameter of the pipe and the length needed.
2000L300
Oct 10, 2010 08:39 PM
rlembitz
Saturn L300
Sep 14, 2009 10:39 PM
Northcutt042
Aug 8, 2009 09:52 PM
mikekishon
Saturn L300
Mar 13, 2009 02:53 PM
deanrp
Saturn L300
Jun 2, 2006 11:16 PM
