03 Saturn l300
I live in Indiana my Saturn won't pass code reads po455 could someone tell me where the can is so I can check the hoses and lines so I can have my car back it's been ,2 months with out it it's not in the back of the car that I have seen I thank you for all your help I'm new on here so bear with me on sending or texting this to anyone
Well the canister is on top of the fuel tank, that’s the bad news. The good news is the evap problems are usually the fuel filler pipe is rusted through. If you remove the rr inner fender you can inspect and or repair the filler pipes. There is a solenoid up near the cap but the tubes rust through and do not hold vacuum for the evap test. If the small overflow pipe is bad just replace it with fuel hose. Same with the large fill pipe. Auto parts stores sell fuel fill hose just measure the outside diameter of the pipe and the length needed.
