Saturn L300, what is this?
There is a black box directly attached fore of the battery it had a chunk taken out and i know it got wet. I need to know what it is but cant find anything on it. I know it got wet a a while back then it went crazy (wipers, lights, locks, horn and everything else going off) and it has sat ever since. recently I jumped it so it could run and get all the bad gas out and it got stuck in park with a security warning but after disconnecting the battery it went away. Also before the security warning came up the tachometer stopped working but the engine was still running. It didn't go crazy again but I need to know what that chip is and how much it will cost. (2002 Saturn L-300 4 door v6)
That box contains the relays for the cooling fans, you may have other problems also. Where are you?
Originally Posted by 02 LW300
(Post 58508)
I would source a used one from a wrecking yard. Should fit all L series 2000-05. It sounds like your car may have the incorrect headlight switch also. The 02 switch does not have an off position. It has auto, park and on. I bought an 02 with an 01 switch and it had lots of flickering lights and clicking relays until corrected. You need a good battery for any further diagnosis, jumping a dead battery just won’t get it.
New part still old problems
(Post 58510)
What part of “you need a good battery” was not clear?
(Post 58510)
Originally Posted by Emb410
....my service soon light is on
That would have been nice to know from the get-go. REPLACE YOUR BATTERY like the man said. Go get the codes read for free at Autozone or similar FOR FREE --they usually lead you to the source of problems. Post as Pxxxx . ---------- You posted to this site for advice. You were given information and advice. You chose to ignore the advice. If you continue to ignore the advice we're providing, there's no point in us trying to help you to solve issues with your vehicle. ------------ No, I'm not being arrogant and holier than thou; I'm simply saying you asked for our advice but you won't follow it. If you don't plan on following our advice, why are you seeking it? Please get the codes read, and post them and get a new battery before asking for more help, because there's nothing more we can do for you until you do. Your choice |
