Horn doesnt work and Air Bag light on!
Old May 7, 2008 | 02:03 PM
skidril's Avatar
Help! I had the rack changed on my L100 and now my airbag light is on and the horn doesnt work.
Any pointers would be greatly appreciated!
Thanks.
</>Edited by: skidril
Old May 7, 2008 | 03:22 PM
Low Saturn's Avatar
Its possible when the rack was off the car, someone spun the steering wheel. This could of damaged the clock spring. The wiring for the airbag and horn is part of the clock spring.
I'd take the car back to where you had it repaired.
Old May 16, 2008 | 09:34 PM
car5car's Avatar
Horn and airbag are two different problems. If screw up look for wire disconnected from horn. If it is OK, check fuse and relay. To fix airbag get a book with wiring diagram.
Old May 16, 2008 | 09:38 PM
Low Saturn's Avatar
Yeah, just forget the fact the both are wired through the clock spring on the steering column. And if that was spun around while the rack was disconnected it would rip the wires apart inside the clock spring.
mrtweaver
Aug 24, 2011 09:26 AM
RussReid
Jul 20, 2008 02:32 PM
95_sl1
May 10, 2008 01:48 AM
Nickolas
Feb 20, 2008 12:38 PM
airedale
May 18, 2006 05:59 PM
