Headlights not shutting off
I'm having an issue with my headlights. I'm not sure if it's in the switch or what is going on. As you know the lights never actually shut off the shut-off position is the automatic lights/day running lights. But they do not shut off even when the key is removed and the engine is shut off. I have even pulled the relay under the hood and they still remain on. Help!
'04 L300 #2 series Yes, I knew about Ebrake . This just started in last week. What dumbfounded me was that with no fuse\relay they were still on ?!?! Did discover that low beams are both out. ( So having switch on and flicked to dim they're off ) . Since lenses are older and cloudy never took lights off brights in probably 2 years . I think though that there is a short somewhere and it's arcing to something else. What other explanation can there be for DRL stay lit with no fuse??? Ugh
Seems like a switch issue.
ADK427
Jun 18, 2021 11:21 AM
