03 L200 cranks but no start.
Old Mar 31, 2021 | 02:37 PM
one4gimp's Avatar
Default 03 L200 cranks but no start.
I'm having an issue with my girlfriend's 03 L200 with a 2.2 Ecotec engine that has approximately 140K miles on it.
It has an intermittent crank but no start issue. It acts like the fuel pump goes out (no fuel pressure on a test gauge but enough to dribble at the test port.)
In the past, I've inspected and cleaned the electrical connections from the fuel pump and it's worked fine for a while before dying again The last two times have come after the engine has idled for
a significant period of time. I've checked spark by grounding the plugs and having someone crank the engine, and it has spark. I've tried jumping pins 87 and 30 at the fuel pump relay but to no avail
I also tried switching relays but again no luck. I've read on other Saturn forums that owners have tried replacing their fuel pumps only to have the problem reappear shortly after. I'm going to try finding the fuel pump ground connection
I've read that it comes from the tail light harness somewhere in the rear. I'm also wondering if this could be related to the BCM issue or another module due to it occurring after a long idle. Anyway after reading various forums
I've never found a definitive answer to the cause. I am a former Saturn tech but left before the L series came along. Does anyone have an answer for this issue?
Old Apr 1, 2021 | 01:18 AM
Andy should be a long shortly to assist you.
S car specialist, trained at the factory?
Feel free to hang around and contribute; I have a 95 and a 97 SC2 one owner vehicles out in the driveway. I'm the closest thing we have to an S Series guru. Feel free to chime in.We need some new blood around here.
Old Apr 1, 2021 | 08:36 AM
I’ll be back tonite after work. I have 02 books I will look at the schematics. Is the car rusty?
Old Apr 2, 2021 | 07:55 AM
one4gimp's Avatar
thanks for the welcome.
Old Apr 2, 2021 | 07:56 AM
one4gimp's Avatar
yes the body is good but there's plenty of rust on the undercarriage
Old Apr 4, 2021 | 11:36 AM
Default It probably needs a fuel pump
Old Nov 13, 2025 | 09:37 PM
Outlookxr08's Avatar
So has anybody figured out what the issue is because I'm facing the same issue now but I just put a fuel pump in 3 months ago
Old Nov 14, 2025 | 10:04 AM
The OP hasn't been back since April 5th of 2021. You ARE NOT going to get an answer. Please go to the correct header for your vehicle and start a new topic. Maybe someone here can help you out.
Old Nov 14, 2025 | 10:29 AM
I did
gmabbott
Saturn L300
Aug 9, 2017 11:11 AM
mattl36567
12
Oct 15, 2013 06:06 PM
markfire68
Mar 31, 2013 05:58 PM
Rizzu7
Feb 19, 2013 12:28 PM
neil18
Mar 18, 2007 01:25 AM
