Water Leaking Onto Floorboard,,,,HELP
Old Aug 24, 2008 | 05:18 PM
c.partain's Avatar
Hey guys, got a problem and need some help. I have an 06 Ion that seems to leak water under the passenger side dashboard (under or behind glovebox). Seems to occur when I have the air conditioner running. I live in Louisiana so there is no possible way I can function without the AC. Can someone please give me a little insight to my problem. Thanks for the help.
Old Aug 25, 2008 | 07:52 AM
TheEngineer's Avatar
you either have a bad heater core, or a bad line comming into the heater core. Alot of times those lines jsut get clogged. But this is something that can be a PITA to repair by yourself since the location is difficult. I suggest bringing it to a mechanic that you trust to repair it
Old Aug 26, 2008 | 08:50 PM
Clogged A/C drain from the evap ..
Old Aug 28, 2008 | 11:12 PM
c.partain's Avatar
How would I remove the clog from the evap drain?
Old Aug 30, 2008 | 04:31 PM
Take it to someone that knows what they are doing. If it''s under warranty can you think of what to do?
spoolnaround
May 25, 2011 08:51 AM
casacano
Sep 6, 2009 05:32 PM
medic2434
Jun 17, 2009 08:13 PM
gregl
Jul 12, 2008 10:45 AM
KELLYM
Jun 29, 2005 06:11 PM
