Hey guys, got a problem and need some help. I have an 06 Ion that seems to leak water under the passenger side dashboard (under or behind glovebox). Seems to occur when I have the air conditioner running. I live in Louisiana so there is no possible way I can function without the AC. Can someone please give me a little insight to my problem. Thanks for the help. |
you either have a bad heater core, or a bad line comming into the heater core. Alot of times those lines jsut get clogged. But this is something that can be a PITA to repair by yourself since the location is difficult. I suggest bringing it to a mechanic that you trust to repair it
Clogged A/C drain from the evap ..
How would I remove the clog from the evap drain? |
Take it to someone that knows what they are doing. If it''s under warranty can you think of what to do?
