Saturn ion cv axle
Old Oct 6, 2024 | 06:03 PM
Jakobk's Avatar
Default Saturn ion cv axle
Hey everyone, I’m replacing a cv axle on a 2006 Saturn ion. I got the axle out with ease however I noticed that the side that’s going into the transmission has a shaft on it and the new axle I have does not. Does anyone have any tricks to remove that shaft without damaging the rubber part of it?
Photo for reference
Old Oct 6, 2024 | 06:30 PM
That piece with the rubber is a seal ride. A new seal and that ride are $11 at Rock Auto.
Look here for instructions.
Old Oct 6, 2024 | 07:52 PM
I learned something today
Thank you, Andy.
Old Oct 6, 2024 | 08:36 PM
Jakobk's Avatar
just wondering if that out shaft sleeve goes into the transfer case? I’m just trying to resolve a issue where the car vibrates when your coasting
Old Oct 6, 2024 | 09:28 PM
Since Ions are only front wheel drive, you do not have a transfer case. You have only a transaxle, your Ion is front wheel drive. It is extremely possible that a bad cv shaft is causing a vibration upon coasting. Does it vibrate under acceleration? It may be a motor mount that lets the engine contact the subframe under compression.
Old Oct 7, 2024 | 01:28 PM
grcauto8453's Avatar
I think you have the intermediate shaft there.
Old Oct 18, 2024 | 02:56 PM
Jakobk's Avatar
Default Update*
So I was able to fix that vibrating problem with changing the cv axle. For those who may or may not have the same issue as me, how I took off the stub/intermediate shaft off the cv axle was with one hand I held the assembly by the stub shaft in the air, and the other I hit the cv axle with a hammer. Make sure to wear steel toed boots as the cv axle falls quickly lol. Hope this helps
Old Oct 19, 2024 | 01:09 AM
Thank you for coming back and adding closure to this. Most people don't bother.
Saturn1337
Aug 24, 2024 03:51 PM
Ddorsey682
Nov 20, 2023 07:34 AM
Megs22
Nov 13, 2022 08:00 AM
Ohio_Guy
Jan 19, 2016 08:11 AM
alstar80j
Mar 22, 2009 07:13 AM
