Rear spring replacement on 07 Ion2
Old 09-09-2019, 04:06 PM
Grbenda's Avatar
Default Rear spring replacement on 07 Ion2
I am replacing the rear springs on my 07 Ion 2 and following a YouTube video it indicated that when I lower the rear axle after disconnecting the shocks and springs should come right out. Mine doesn't. There appears to be tension on the springs. Am I missing somet or doing something wrong?
Old 09-28-2019, 02:32 AM
DropDead's Avatar
Drop the rear beam on both sides. Use a prybar or something to pop the bottom out. Then wiggle it around. Its pretty easy
Old 09-28-2019, 03:20 AM
If you ever want to know how difficult or how much a PITA a particular portion of an automotive "operation" demonstrated in a YouTube video is, look very carefully at the tools present in the "before the step" shots, the tools present or in the background in the "after the step" shots, and the angle of the incoming sunlight (if applicable)
SaturnSteve
18
02-05-2023 08:05 AM
3rdEye2020
01-28-2020 08:43 PM
radar2k
03-15-2009 11:49 AM
VueRedline04
10-11-2008 11:53 AM
Quick Reply: Rear spring replacement on 07 Ion2
