Need Clutch Line, 2004 Saturn Ion
Old Jun 24, 2024 | 08:34 PM
  #21
obi1's Avatar
Originally Posted by JBSaturnIon3
Yeah, I have been there and traced out the actual seller, called them, and they don't have them. It is some sort of front end for various dealers around the country and their data is old from what dealers I called told me.
I sent DropDead a PM and hopefully I can get a line from him. Worst case, maybe I can find some hydraulic hose and crimp it on the old connectors, but what a pain.
Thanks for the help.
JB
sorry i was wondering if you had another one of these? hoses and if you did would you plz give me a call at 4026290747
Old Jun 24, 2024 | 08:36 PM
  #22
obi1's Avatar
do you have one of these I can purchase form you?
Old Jul 1, 2025 | 03:01 PM
  #23
Unknown999's Avatar
Default I am also facing a seized line at the Slave Cylinder connection.
Originally Posted by badecotec
I took your advice with the 2-3 vice grips. i soaked my line on the slave cylinder end with pb blaster and wd40. what ended up working for me was not tapping the vice grips with a hammer or leveraging with a flathead screwdriver. but instead using a wrench that fit the line and leveraging the line out(while holding the last and stronger of the two vice grips).
finally i saw the first part of thin rusted metal fitting and the rest came right out.
badecotec
Would you mind elaborating alittle bit more on the method you used to get your line off? I have tried the multiple vice grips, with tapping the hammer against them, but that did not work. What exactly do you mean when you said you where using a wrench that fit the line and leveraging the line out, while holding the vice grips? And would you happen to remember what size wrench is was that you used. Any help that I could get would be greatly appreciated.
Amanda, CA
May 19, 2025 04:04 PM
racinrob3
May 16, 2021 06:03 AM
Mrs.Cross
Aug 20, 2020 12:32 AM
Arielgrace85
Aug 17, 2019 05:15 PM
JBSaturnIon
Feb 21, 2014 11:49 PM
