Help please help I'm on SSI disabled and cannot get anyone to help me identify this p
Old Apr 23, 2018 | 01:01 AM
Lynn Ross's Avatar
Default Car is stuck on stupid lol
Okay so I bought car used and the head was blown replaced engine and it ran like a dream no problems at all then I noticed a little hopping and then found out the input output sensor was cracked thank you derf.. for helping me
after I changed that 60 minutes I also changed the tranny fluid not filter or gasket not yet I was told 4.5 quarts I bought 9 because based on specs I needed more so started it up took off ran great for a block boom hopped again and rpm reved speedometer bounced shut off started drove home
I'm at a loss it purrs now when you start it
There is a slight noise almost like power steering low noise I've owned car a year 8 months out of this year it's been down I desperately need a car please help no code other than p2430
Also the traction light keeps coming on and off
Old Apr 23, 2018 | 01:14 AM
Lynn Ross's Avatar
Good luck with it, Lynn. Like I said, if you tell us where you are and we have a member in your area, they may offer to help you. If you're close to Lake Wales, Florida, I'll come help you. Two disabled people working on a Saturn. Someone would have to get video! LOL I'll expect a cold beer or two, though.
Im in crescent City CA I just saw this post as I was going back through
Old Apr 23, 2018 | 01:15 AM
Lynn Ross's Avatar
Originally Posted by 02 LW300
Ok Lynn let’s discuss your car and its problems. The p2430 is a secondary air pump issue and should not affect drivablility at all. What problems are you having, I suspect transmission problems since you asked for help with a sensor.
We will help if we can!
Thank you I posted it on feed
Old Apr 23, 2018 | 10:12 AM
If you drained the 4t45 transmission by dropping the pan you need 7 quarts to refill to the proper level.
Old Apr 23, 2018 | 10:18 AM
Lynn Ross's Avatar
hi there did not drop pain this time should i have just did it so if i didnt the. Level should be okay with 4.5 quarts
Old Apr 23, 2018 | 10:25 PM
Is there a drain plug on your trans? My Lw300 did not have a drain plug so I dropped the pan. Either way if you drain the pan it holds 7 quarts.
Old Apr 24, 2018 | 12:06 AM
Lynn Ross's Avatar
Yes there is a drainplug on side they were saying the torque converter held approximately 3 quarts and not to put more in it should I add more to the car
Old Apr 24, 2018 | 10:04 AM
From what I can find the transmission holds 10 quarts if completely empty. That includes the torque converter that holds 3. So I would put some more oil in it and see what happens. ��
Old Apr 30, 2018 | 12:22 PM
Lynn Ross's Avatar
Default Found the problem torque convertor
Okay so finally got tired of it sitting so called mobile mechanic
no codes nothing the engine perfect no codes
But after researching it every symptom it has points to the torque convertor so my questions is to verify my transmission is the 6t40 and the GM number I found 24239678 are there sub numbers
For this part also found this part number but cannot get AutoZone to locate one 3230908075
please can someone help me thank you
Please I need help
Old May 3, 2018 | 09:58 AM
The drain and refill on a 6t40 is 4.5 to 6.5 quarts. I would still try a little more oil. The transmission has to be removed to replace the torque converter. You may need a professional transmission shop help, they will be able to properly diagnose your problem. It may be a simple solenoid problem.
