Coolant Leak
Old Jun 7, 2013 | 07:27 PM
vegas01's Avatar
Default Coolant Leak
Hey, I just signed up here. Any Aura owners have problems with water pumps and if so at how many miles. I have a very slow leak (behind the RF tire) and I have to add a little over 1/2 a quart of anti-freeze every 200 miles
Old Jun 7, 2013 | 09:27 PM
Not many AURA owners on here.........though it might have been a good idea to start a new thread and not attach it to an old one that has nothing to do with your question.
Old Jun 7, 2013 | 10:03 PM
My wife's got an '09 Aura XE (4 cyl). Less than 100,000 on the clock, and no coolant leaks, noises or problems.
Old Jun 8, 2013 | 07:32 AM
Post now in it's own thread. Aura or any other car I think it's time the leak is found and fixed. Unless you rather find yourself standing on the side of the road wondering what to do next.
Old Jun 8, 2013 | 01:44 PM
Yep I'll guess any car on the road has had a water pump go bad.........time to fix it is now.
Old Sep 2, 2013 | 11:16 AM
tysonsdad's Avatar
Are you sure its the water pump, my 07 Aura had a coolant leak by the RF tire and after pressure testing the cooling system i found it was the radiator, if its your water pump its four bolts and easy to get to from the bottom of car, it could also be a crossover tube gasket which is right above your water pump, it could also be a thermostat housing gasket which is close to the water pump. diagnose the problem dont just throw parts at it. if its the 3.5 its fairly easy to access the front of the engine after you pull the front tire and the lower plastic inner fender well. good luck and if you need any more info let me know.
Tysonsdad
Old Jun 10, 2015 | 01:30 AM
dhanson94's Avatar
Tysonsdad
Actually 2 crossover tube gaskets. The rear one on mine just blew out last week. Kind of a pain to replace, but a video on youtube that gets you there. When leaking out the rear crossover tube gasket, the coolant ends up dripping off the frame near the lower control arm. Pic of the blown gasket attached.
sc2boombarr
Jan 8, 2009 09:58 PM
s1dest3pnate
Dec 7, 2008 12:23 PM
Icurl4
Feb 19, 2007 08:20 PM
rgjoslin
Feb 11, 2007 10:31 AM
LS2guy
Aug 22, 2005 03:17 PM
