1998 sc2 coolant leak
Old Dec 11, 2008 | 06:13 PM
sc2boombarr's Avatar
I have a 98 sc2 with about 157,000 miles that has an inconsistent coolant leak.
Leak size on ground range from a couple of drops to 2''x2'' spot.
The idiot light does not always come on.
It appears to drips from somewhere above or around the the RH side of the engine. The drip shows up under the RH front A arm and plastic shield that covers underside of radiator.
I replaced the radiator and hoses about a 3 weeks ago.
Any advice would be appreciated.
Old Dec 11, 2008 | 10:53 PM
Check the radiator coolant bottle. Make sure 1) the coolant cap is working properly, and 2) that the coolant bottle is filled to the proper level. Overfilling the bottle could cause the marks you mention ...
Old Jan 8, 2009 | 09:56 PM
Thanks for the suggestions. Root cause of problem leaking water pump. Potentially caused by new radiator = increase pressure.
Old Jan 8, 2009 | 09:58 PM
Glad you located/fixed your problem. Hope 2009 is a good year for you
kensat
Nov 30, 2010 05:12 PM
s1dest3pnate
Dec 7, 2008 12:23 PM
Icurl4
Feb 19, 2007 08:20 PM
rgjoslin
Feb 11, 2007 10:31 AM
LS2guy
Aug 22, 2005 03:17 PM
