Misfire
Old Feb 19, 2025 | 09:10 PM
Richie7930's Avatar
Default Misfire
1.8litre 2009 astra the car runs great when cold started, after driving for about a mile or two it gets a bad misfire sometimes on more than 1 cylinder, after driving for a bit it goes away in the lower rpms and progressively goes away in higher rpms until its just gone and runs amazing after not sure what the issue could be. I just fixed the fuel pump and its getting good pressure
Old Feb 20, 2025 | 02:52 AM
Codes?
And what are the codes present in each operational mode described?
Why was the fuel pump replaced?
Old Feb 20, 2025 | 03:19 PM
grcauto8453's Avatar
Sounds like it develops a leak with the expanding metal. Intake gasket maybe. Need the codes and be ready to test.
Old Feb 21, 2025 | 12:34 PM
Richie7930's Avatar
it ended up being the ignition coil pack
Old Feb 21, 2025 | 01:17 PM
How did you diagnose it?
Old Feb 22, 2025 | 11:11 AM
Richie7930's Avatar
i remember that a friends chevy cruze with the 1.8 was having similar issues and it it solved his problem so i took one off a parts car he had to see if it helped and it did
Old Feb 23, 2025 | 10:26 AM
Works for me
TrafficCone
Sep 26, 2023 09:51 AM
lbolton64
Mar 31, 2018 09:44 PM
Grsulman
Aug 14, 2016 02:02 PM
mmsvob
Mar 27, 2011 01:05 PM
rchinny
Mar 7, 2006 11:19 PM
