How to check Transmission oil
Old Feb 21, 2025 | 12:38 PM
Richie7930's Avatar
Default How to check Transmission oil
Just curious on if theres a way to check the level of oil so i know how much to top it up or if i have to drain it and re fill and if so is there another way to drain it than dropping the pan on the bottom standard transmission not automtaic
Old Feb 21, 2025 | 01:15 PM
Don't know an Astra from an astral plane, But I reckon there is a level check hole near the top of the case on the side.
The transmission must be up to operating temperature for the level to be determined properly. The vehicle also must be level.
The transmission is properly filled when, at operating temperature, you remove that bolt and liquid is just weeping out of the hole. Add more fluid if necessary to make it so, then replace the bolt and get on with your life
Old Feb 23, 2025 | 05:09 PM
Charm.li says the inspection plug is just below and behind the driver’s side axle. The fill location is through the reverse light switch hole on the front of the transmission. You might be able to remove the oil with a suction gun or drop the pan. Hold 1.6L of a GM spec oil.
Try charm.li and look up your car. You have to open up the menus to find what you need.
Terry76
Jan 12, 2025 08:41 PM
Ohio_Guy
Jan 21, 2016 02:47 PM
Flaxmoore
Jan 16, 2012 09:21 PM
gunz4all
Jul 5, 2009 01:35 PM
eg8hardcore
Jun 28, 2009 06:35 PM
