Astra electrical gremlin any help?
Old Feb 25, 2025 | 10:27 AM
Cass1989's Avatar
Default Astra electrical gremlin any help?
Hey all!
wondering if anyone’s come across this.2008 astra xe 4 dr. Suddenly I lost all central locking. Button on the dash doesn’t work. Then noticed no windows front or rear. No interior light and all rear lights do not work. I have checked all fuses. I’m getting power right at the fuses but no success. I found some broken wires in the rear passenger door repaired but still no luck! Anyone have any ideas? Thank you!
Old Feb 25, 2025 | 10:29 AM
Sounds like everything in the entire car is grounded in one splice pack, and that ground has come loose.
Just kidding. I'll post you a link to the wiring diagram.
Old Feb 25, 2025 | 10:31 AM
Cass1989's Avatar
I was thinking there has to be something that connects them all but trying to find a diagram has been rough! Thank you! It’s driving me mental!
Old Feb 25, 2025 | 10:40 AM
Link to index of wiring schematics. Click on blue area to go to given schematic
2008 Astra diagrams as year was not listed.
https://charm.li/Saturn/2008/Astra%2...matic%20Index/
Old Feb 25, 2025 | 10:46 AM
Cass1989's Avatar
Thanks so much! I edited it right after as I realised I didn’t put year but that’s perfect! I will check all grounds first and hope for the best for what are the chances of having every single wire broken haha. Thank you!!
Old Feb 25, 2025 | 11:26 AM
Cass1989's Avatar
Well of course I wouldn’t be lucky with the grounds. Am I blind or is there anything else that connects all these circuits? I could also just be dumb cos I’ve looked at this thing for days and it’s pissing me off lol
Old Feb 25, 2025 | 03:09 PM
Cass1989's Avatar
Thank you for the diagrams. Did all wiring testing which shows my rear fuse box is pooched! Any idea if I can put in a used one or if it needs to be programmed?
Old Feb 25, 2025 | 07:40 PM
Why would it need to be programmed?
I would disassemble and see exactly what you need so you can finish the work in 1 sitting
Old Feb 25, 2025 | 07:42 PM
Cass1989's Avatar
I went and grabbed one from pick and pull. Everything works great now. I had been told they needed to be programmed as it was like a bcm inside the fusebox. But that’s not the case. Everything works like a dream!
Old Feb 25, 2025 | 07:45 PM
Awesome.
​​Any clue as to what caused the meltdown?
