Sc2
If you leave the primer coat and paint over it you will likely be fine for a few years before patches shows up again.
Thanks for the advice.
I haven't done much since taking the photos. I sanded the front bumper a bit more and sanded the failed paint on the rear bumper. I sanded the rear damage down to the plastic on that rear corner. I feathered it out and shot some primer mostly to cover it for now.
I'm still not sure what I will do with the hood. I'm thinking of doing most of the sanding and I might get an estimate on the cost of just painting the hood from a shop. The hood is the biggest problem for me. No garage unless I borrow one.
Some people are driven not only by practicality but also by symmetry. Myself included. By symmetry I mean matching parts make the whole.
That and this gentleman seems to feel that this vehicle is an extension of himself so he wishes to project through it the best image he can. Just as you stopped wearing yellow slacks to work in the '90s, he wants the hood to be the way it should in his mind.
I agree with you, man. I miss rebuilding engines.
I am just going to try to do something with the hood that is on it. I just want to make it look better than it does now. a coat of paint after sanding should hold up for a while. If the paint fails, it won't look worse than now.
Paint is definitely a pain. I had to postpone work on it for a while. Maybe have it done in a couple weeks.
I can't do the major work, like trans or engine replace. So far, it has been holding up pretty good for the last 12ys that I've had it. The last thing I repaired was doing a starter replace, which is difficult on the SC2 when just on jack stands.
Two years ago I replaced the entire exhaust system which was surprisingly easy. It was actually easier than replacing the starter. lol So far lucky with the after market cat. Not triggering any codes.
